Hi every one. My media coder pmp software is little bit older one. It does not support latest formats of video files. I want to upgrade to the latest version. How can I do this without doing any payments? Will the latest version compatible with windows 8 64 bit operating system.
How to update media coder pmp software?
Hello Matthew Leon,
If you want to update your software then you can use default update of the software but if that thing is not in a working condition then you can download the latest version of the software from the below link. It is a free of cost version and you can find it very useful for you to use. All you need is to go to the below link and download the software.
http://mediacoder-pmp-edition.updatestar.com/en
Hi Mathew Leon,
You can easily update your current media coder pmp software to the latest software releases by downloading it . It comes with support for the following latest video compression formats.H.264, VP8, XviD, DivX, MPEG 1/2/4, Flash Video, VP8, Theora, Dirac, H.263, Real Video, Windows Media Video, MJPEG.
The program is absolutely packed with options to help you configure every step of the conversion process to the new updates.
You can download the software by clicking in this link
I hope this will help you.
I suggest that you just download the newest version through this link:
https://www.downloadcrew.com/article/4464-mediacoder_64-bit
It is free and it comes with many options that you can do while converting to your desired format . It supports just about any video formats and audio files you would like to convert. And you don’t need to worry because this version is compatible with windows 8, 64- bit operating system.
