Hi Experts,
I want to update multiple music id tags for my database.I am having a database of music id tags and want to keep it up todate.so I need to feed new data.Can anyone suggest me a website to achieve this.Thanks.
Deangellopeter
How to update multiple music id tags ?
Try mp3Tag Pro (https://www.mymusictools.com/error.htm).
It sorts 8000+ music files into new folders very easily according to the pattern that you specify. It is very simple and fast.
However, mp3Tag Pro only works for Windows and it is not very user friendly. It is also by donation meaning that one needs to encourage the author with a small contribution of say $1 or a postcard.
Media Monkey is another option (http://www.mediamonkey.com). It is available for free and you can delete or rename both the library and the computer. It tags album art correctly and automatically organizes music into logical folders .
Unfortunately, it also only works for Windows.
