I am using windows xp and my drivers that I am using is pretty old. That is why, I want to update the drivers of my pc, especially
the video drivers.But , I don't know how to update the drivers of my pc. Any advice would be appreciated.Thanks.
How to update my drivers in Windows XP?
Hey Arnold Ortiz!
Don't worry; I am here to help you. You can update your drivers manually or with the help of software. Let us have a look on both methods.
Method 1:
1. Insert your Drivers CD in CD/DVD Rom.
2. Right click on "My Computer" and select properties.
3. Click on Hardware Tab and open Device Manager.
4. Click on Display Adapter (Or the driver which you want to update).
5. Select your VGA driver and right click on it.
6. Select "Update Driver". In the Wizard, use the Advanced settings and browse your CD path.
7. Click on Ok button and your drivers will be updated.
Method 2:
You can use software like Driver Genius to download the latest. This software will automatically download the latest software for your computer. You can search on internet for this software.
Thanks
Search Drivers in google search ( for example if it is dell, than search in google drives for xp dell & click on first result).After complete download it will automatically installed.
