How to update nvidia latest divers
I am using NVIDIA 550 and I want to update my drivers.
How can I update the latest drivers so that I can play the latest games?
Thanks in advance.
Best Answer by Howard william
Answered By 0 points N/A #162738
If you want to update your NVIDIA driver. 1st go to the NVIDIA driver site.
Then you can manually download driver compatible with your graphics card and windows OS.
You can also automatically find it from the site.
You can search for beta and whql drivers and find if your system compatible with it or not.
Download it and execute it.
Then follow the easy installation process.
Answered By 0 points N/A #162739
Hi Dear,
NVIDIA Video Driver is so easy to update. You can update or download it easily from many websites.
Now I am going to tell you a very easy method to update not only NVIDIA, it can update all drivers very easily.
You have to go to the website https://www.driveridentifier.com/ then download the software Driver Identifier. Run it on your system it will scan your computer and will tell you that which driver is required to update. Then it will redirect you to that driver download page. From that page you can easily download driver and install it free of cost.
Regards.
