How to update Tune bug vibe surface portable speakers software
Hello, how are you all? I hope well. I have a Tune bug vibe surface portable speaker. I used it in Windows 8. But one of my friends liked it and bought it. He is a windows XP user. The problem is, the Tune bug vibe surface portable speaker want's the XP version software. Is here someone who could help?
Answered By 590495 points N/A #187552
I’m not sure if you are really referring to the Tunebug Vibe Portable SurfaceSound speaker or to another kind of speakers because with Tunebug, I don’t think it will ask for a driver when used on a PC running Microsoft Windows XP or any other operating systems. If you are then there’s something wrong about your question.
The Tunebug Vibe Portable SurfaceSound speaker is an ultra-portable sound generator that can be used on any device with 3.5 millimeter jack. That means it is used like a headset or an earphone where you only need to plug in the jack to the device’s port and that’s it. The Tunebug Vibe Portable SurfaceSound speaker uses its patented SurfaceSound technology that allows sound waves to pass through the surfaces it rests on.
With this technology, it can turn numerous surfaces into a flat panel speaker. Unfortunately, after checking it on Amazon, I’ve seen negative reviews from disappointed customers.
