How to update vga intel hd graphics laptop?
Hi guys,
How to update vga intel hd graphics laptop? I am using windows 7 starter operating system and wants to know if it is already included in the package of windows operating system updates. Hd graphics is very important for some gaming and video viewing to make It clear for the audience or user.
Expecting some help, thank you.
Best Answer by Allen Kenneth
Answered By 0 points N/A #186507
Hi Benjamin,
You can update it manually by right clicking Computer>locate Device Manager then click the little arrow at the left side in the title Display adapters then right click the sub title and choose update driver. Or just turn on automatic updates at the Control Panel.
Answered By 20 points N/A #186508
Hello Benjamin,
Straightforward solution is to update your Graphics drivers using the Device manager of your computer.  Can be done in two ways, automatic update using internet or you have to manually download the latest version of Graphic drivers as a .zip/.rar file from the manufacturers web site and then install.
Either way your question is solved.
Follow the steps given below to perform an automatic update of drivers:
Make sure you are connected to internet.
Right click at the "My Computer" icon, Go to "Properties", you will be able to see "Device manager" tab to the left side of the window. Click and proceed through. A separate window will open. From the list of drivers, find "Display adapters", double click to open the driver properties. Change the tab to "Driver" and click the "Update driver" button and from the two buttons, pick the button to "Search automatically for updated driver software". The update process will start automatically then. After installation, reboot the machine and there you go! You have the latest Intel Graphics Drivers.
For the manual installation: First you have to download the specific driver from the manufacturers web site. Use this link to land on the page of Intel Download Center: https://downloadcenter.intel.com/
Get the downloaded .zip or .rar archive files extracted to a known location. And follow the same method we used until the place where you have to choose an update option.
In this case where you have the drivers already, you have to go for the second option and browse your computer for drivers. Give the driver software file when asked  and install it. Reboot is required.
Hope this info will help you. Regards!
