andrewjohn
30 points
Posted on - 09/08/2012
Hi Experts,
I am having 737 dolby software on my laptop and need to upgrade it to the latest version.Then I do not need to reinstall it.Can you provide me the instructions to achieve this.Thanks.
Andrewjohn
How upgrade 737 dolby software ?
There are many ways of upgrading your software and the easiest is to do it just from within the application. Open the application you want to upgrade then check the available menus on top of the program to see if the upgrade button is in there. Or you may also check the application’s Help menu for the Upgrade link. It is usually located there including the activation link in some programs.
If you see the upgrade link there just click on it then follow the succeeding on-screen instructions and then wait for it to finish. Be sure that your computer has an active internet connection before doing the upgrade to avoid any problems. It’s also best to do the upgrade during daytime or during off-peak hours so you can be sure to have a good and fast connection.
Try to launch your Dolby 737 software and then click on the Help tab and then check if there is an update available. Or you can also go to the Dolby website at https://www.dolby.com/us/en/index.html and search for your product and then check for updates. A firm internet connection is required for downloading updates. You do not need to remove your old Dolby software as updates will be installed and replace your old software automatically.
