How to upgrade firmware telnet ?
I want to upgrade the firmwire of my FTP. It is telnet enabled. But I am failing to upgrade it. How to upgrade firmware telnet? Will there be any problem for my server if I upgrade the firmware?
Thank You
Thank You
You’re with a very common problem that many a FTP users face. But you are lucky that your FTP firmware is TELNET enabled. So, you’ll get some privileges upgrading the firmware. It’s, somehow, not a very easy process to upgrade it. Here’s a site which shall help you get the solution:
For further detailed help you can take tips from this .pdf file:
There remains a possibility of having problem for the server while upgrading. But proper upgrade and physical precaution of the parts can avoid them.
