How To Upgrade Graphics Card In Simple Steps
Hi. I am not very hands-on with the software related to IT. I would like to know the steps for upgrading the graphics card. How to upgrade graphics card? Please reply ASAP. Thanks in advance.
Hi. To know how to upgrade graphics card first, switch the PC off. For this, open the CPU. Locate the slot of graphics slot on the CPU and open the CPU and find out where the graphics card can be inserted. Then, after the slot is determined, plug in the graphics card, close the PC and then replace the screws if there are any. Next, before turning the PC on, ensure that all the devices are connected properly. Then, turn the computer on after which Windows will detect the new card and accordingly install drivers. Select the start menu and then click on control panel.Â
Then, click on hardware and sound from the options mentioned. Following this, click on the device manager. Then, next to the + sign which is present next to the display adapters, the graphics card needs to be right-clicked on and then select properties.
Hope we helped.
