How To Upgrade Microsoft Office 2010 To 2013 Using Easy Steps
Hi. I am not very familiar with MS-Office. How to upgrade Microsoft Office 2010 to 2013? Please reply ASAP. Thanks in advance.
Hi. To learn how to upgrade Microsoft Office 2010 to 2013, first download the zip file of MS-Office 2013 and once it downloads, unzip the file into a different folder which can be easily accessed by you. Next, to unzip the file, right-click on the zip file and then extract all. Then, inside the unzipped folder, find the .cmd file.
Then, to install the MS-Office 2013, first launch the .cmd file and when asked if you would like the file to make changes to the computer, click on yes. Then, select the option upgrade. The features which should be downloaded can be selected as well by clicking on the customise option. Wait while the downloading takes place. Click on close and to reboot the system, click on yes.
Hope we helped.
