Mobile Me is the best thing I have had for years. It gives me what I need especially the synchronization of my calendar. I can access my calendar from my phone, IPod, computers and even through web browsers. But now I am having issues with Cloud, as it requires a new account for mobile phones. Then, Mobile Me users are required to upgrade from a Mobile Me account to a Cloud account. How do I upgrade to a Cloud account and what is the safest and easiest way to do it?
How to upgrade from a Mobile Me account to a Cloud account
Synchronization of calendar on iCloud may encounter problems on the process of synchronizations. When accessing calendars in iPhone, iPod and computers then that means, there is no problem with the syncronizations.
Cloud computing might think, there is a duplicate files saved in the cloud server. Users that has Google docs account is allowed to set-up Mobile documents such as in Amazon but sometimes you may encounter problem but not so harmless in effect.
It is required you to have an account on iCloud such as in Google cloud to synchronize calendars. You can create many free accounts when its needed but when a folder is created with the same file name, this could caused you problems. So, it is save to delete the empty folder to synchronize calendars on iCloud but be aware of the folder you want to remove, because this might contain the data of the calendar you want to synchronizd on iCloud.
