How to upgrade samsung 3500i mobile wireless software?
Greetings Techyv members. Please tell me the steps how to upgrade Samsung 3500i mobile wireless software latest edition version. What are the step by step process for this kind of upgrade? What will this update do to my current system? Please include a full overview regarding Samsung 3500i mobile wireless software. It would be a big help.
Answered By 5 points N/A #152987
Hi! You can update your Samsung 3500i with the use of "Kies", this is supported of samsung. Download and install this application to your computer, once you connect your phone to your computer it will automatically check for an update and it will ask you if you want to update your phone.
These are the system requirements:
1. Operating system – Windows 7, vista, XP (32 and 64 bit)
2. Software – .Net framework 3.5 SP! And above, ActiveSync (for Windows XP)
3. Screen resolution – 1024 x 768
4. Minimum RAM – 1GB
