How to upgrade Yahoo Messenger Version
Dear upgrade is a very necessary function in computer software as well as technology improves so its essential to upgrade the software with the latest technology. While Yahoo messenger is well reputed chat, and communication software now a days and yahoo by default having a built-in feature to upgrade its software from old one to new one.Â
Well mostly it stuck off during the up gradation process you can upgrade your yahoo messenger software to go this website https://messenger.yahoo.com/ there you will find the options to upgrade your yahoo messenger now a days yahoo messenger 10.1 is the latest version of yahoo it will take some minutes to upgrade after upgrading restart your computer and your yahoo new messenger will be able to work.
Here’s how to update your yahoo messenger. Open your Yahoo Messenger and then log-in to your account. Click the Help menu then select Check for Updates. After clicking the Check for Updates, you will be redirected to the Yahoo Messenger site for the update. The site will show you if an update is available for your version of Yahoo Messenger.
If available, you will be instructed how to update your Yahoo Messenger. Just follow the simple instructions. You will be asked to click the Download Now to download the latest Yahoo Messenger, then after the download has run the downloaded application to begin the installation then just follow the wizard and respond to the prompts and wait until the installation finished.
Dear Zabair,
Open your yahoo messenger then login your account. Select the help menu and check for updates or visit the site https://messenger.yahoo.com/ then you will be able to upgrade.Â
