What site can I upload a 4GB video file without getting any issues? Most of the sites I tried has a problem on uploading process so can anyone tell me where and how I can download a 4GB video file. Thank you.
How to upload 4gb video in net will be done
Hello
There  are various cloud-based websites which enables you to upload everything including big video files. I will name some of them:Â
https://www.dropbox.com/
https://www.ubuntu.com/
etc. Also you can upload it on YouTube or Vimeo and save it there for as long as you wish. Of course, all of these sites are free to use, so try them and see which one is best for you.
Hello Madison,
You can easily upload your video files over 4GB you just need to follow some instructions if you really want to enjoy your big uploading without any problem. I would recommend you software to upload your big files.
     Download software ‘’TerboFTP’’ by open this link.
          http://soft.udm4.com/Network-and-Internet/TurboFTP.html
·        After download you have to install this software.
·        It will open after installation process.
·        You have to give your IP address and login details to upload over insecure network.
It is secure having wealth of features to provide an easy and reliable way to transfer files over internet. Here you can see the image of this software.
