guy golle
20 points
Posted on - 04/04/2013
Hello Techyv Users and Experts,
I Bought HCL ME tablet recently. I have created some documents on this tablet. Now I want to upload this document to my Home Windows XP Desktop PC. Please provide me some help to upload document from tablet to Pc. Thanks in Advance.
How to upload document from tablet HCL ME.
Hello there Guy,
If you are new in using Android Tablet then you are in the right track in asking some question.
The term is not upload but it is transferring file from your Tablet to your PC.
There is an article could help you achieve your goal.Â
Hope that article helps you.
Roland.
Your tablet comes with a cable that has one end as USB and one as OTG. You need to use this cable in order to connect to your home PC through the USB Port.
After the connection is made, all you need to do is use your current file browser and copy the files you created to the home computer.
With the files copied, and assuming they’re compatible with the OS, you can now use them on your Windows XP system.
The cable should have this appearance.
