How To Upload Files From ipad Using Some Simple Steps
Hi. I have recently purchased an iPad, and I don’t know how to upload files from the iPad. How to upload files from iPad? Please reply ASAP. Thanks in advance.
Hi. To learn how to upload files from iPad, first, add music to the iTunes library and using a USB cable, connect the iPad to the computer. Then, select the music menu and then sync the music to the iPad. Then, click on movies and sync the movies to the iPad. Then, select the photos and sync photos in the iPad.
Then, select the source of the photo from which you will access the pictures. Select either all photos or selected folders from the folder containing the pictures. Then, with iTunes, sync the content in iPad and then click on apply or sync. In this way, you will be able to sync everything that you have selected in the iPad.
Hope we helped.
