Angela King
10 points
Posted on - 11/16/2012
Hi to everyone,
How to upload multiple pdf file? I would like to upload more than ten important pdf files in my yahoomail email address account but I don’t have a clue if the email address is capable of handling multiple pdf files. I have to know the file size limit of the email software.
Thank you.
How to upload multiple PDF file?
You can only send a file extended maximum up to 25mb through the Yahoo mail. You can attach multiple pdf files, but only within the range of 25mb. This applies only when you send any file through Yahoo as an email. But you can easily and securely send a file upto 2GB through "YouSendIt". This is a solution provided by Yahoo in order to send a large file through Yahoo mail. Follow the following steps in order to send a file through "YouSendIt".
* Log into Yahoo mail.
* Then select "Compose Message".
* Then click on "Attachments" and then click on "Attach Large Files", then browse the file you want to attach to the email.
* Then Yahoo will automatically give you the option to send your file through "YouSendIt".
* Then accept the terms and conditions and click "OK".
* Then the application will ask the path to the attachment again and simply follow the onscreen instructions.
This application also allows you to use passwords and much more secure options. But the storage is limited to 2GB.
