sen jamie
Posted on - 02/06/2013
Hello expert,
My friend is using 2005 RedistributableVMware visual c++ software on his computer. He told me when he was working on this software he cannot obtain any new tools in this software. Is it possible to download tools for this or can you send me any latest version of this software?
How to use 2005 RedistributableVMware visual c++ software
Wassup San Jemie, I believe I will be able to help you with this question, there are usually no latest software for this version of software since it is a bit outdated, there are no tools for the software.
You can however update the software regularly to keep up to date with the functionality. The software was originally built just for update and upgrade.
I hope this solves your query
Thanks
