I had my house installed with CCTV system that records to a digital video recorder (DVR). In accessing into DVR, it has a facility that allows me monitor what's happening by the use of internet when I'm away, but it seems I can only access the web address via Internet Explorer, as the system use ActiveX control.
Is there other way to access my system more conveniently and less hassle? Can I view my cameras via ActiveX controls using my Android mobile phone?
How to use “ActiveX CCTV software on android” on my mobile phone?
Hi Laurenz,
Find below the answer to your question,
I want you to know that ActiveX is meant for running software components within windows and internet explorer. It is a proprietary Microsoft Technology. Thus, ActiveX is not available on Android devices. It is not also possible for you to replace your DVR’s software with different software.
Tech Tip : Get one click remote access to all your android apps on any device(PC/Mac/android/iOS) by loading Bluestacks onto citrix xendesktop available at an affordable citrix xendesktop pricing. You can also access complete MS office suite on the same xendesktop with O365CloudExperts.
I hope I have answered your question.
Hi Laurenz,
Most CCTV cameras and DVRs usually depend on ActiveX for playback/recording. It wasn't possible before to make use of your Android phone for monitoring but there have been a couple of developed apps that might work for your CCTVs. One of them is tinyCam Monitor free by Tiny Solutions LLC. Here are a dose of its features:
Features of tinyCam Monitor FREE edition:
– Support for M-JPEG based devices of all major vendors, e.g. Axis, FOSCAM, D-Link, Edimax, Panasonic, Pixord, TRENDnet, Mobotix, Vivotek
– Support for up to 16 cams (4 simultaneously)
– 3 multiple camera layouts
– Sequence mode
– One click camera sharing by email
– Import/export settings to SD or Dropbox service
– Control Pan/Tilt/Zoom (PTZ) enabled devices
– Digital zoom
– Snapshot to SD card
– No ads
If you want to learn more about this application, check this site http://www.appbrain.com/app/com.alexvas.dvr
Hope this helps.
