How To Use Adobe Acrobat Convert PDF To Excel?
I have a PDF file that contains several tables. These tables I need to convert it to excel file and perform calculation operations on the data. Can I use Adobe acrobat convert PDF to excel?
To convert PDF to Excel file you will require a version of Adobe Acrobat DC installed in your computer. Then follow the steps.
Step 1: Open the PDF file in Adobe Acrobat DC
Step 2: Click on Export option from the File menu.
Step 3: In the format select Excel or Spreadsheet format.
Step 4: Scanned images will be automatically being converted into text format if any.
Step 5: Save the file with the name and specify the location.
If you have a PDF file that contains tables that need to be calculated in Microsoft Office Excel, the best way to work on the tables is to convert the PDF file into Microsoft Office Excel format. The easiest way to do this without installing an application is online. Go to PDF to Excel to convert your file.
Here, you can upload your PDF file and convert it into Microsoft Office Excel format. Once the file is uploaded, you can begin converting by clicking “Convert”. Once the conversion is finished, you can download the converted file immediately. You will never be asked to enter your email address like with other websites.
