How to use Adobe illustrator for ubuntu
how to use  adobe illustrator for ubuntu please mention the steps for installing and using adobe illustrator for ubuntu
Yes you can use Adobe illustrator for Ubuntu. A fantastic program to illustrating someone ideas. Unfortunately you don't have that on Ubuntu Linux directly But Adobe illustrator still can installed in Ubuntu Linux and you can work on it.
1.Installing illustrator : You have to choose correct version of illustrator run under Linux and probably its version 8 which is best to use.
2. Install wine : Wine is made for Linux because those programs which don't seem to install or they are not made for Ubuntu. Its install it
3 Install adobe illustrator : Click on illustrator installer and the wine program will take it  and install it by itself. You can find then your illustrator in Application—> wine—->Programs.
