warcup john
Posted on - 05/31/2013
I'm currently abroad to represent our company in a convention. I brought with me some documents that I have to study and approve of. I have to send these documents back with my seal of approval via PDF through email. How do I use the adobe sign and seal? Do you know any tutorials on how to use it?
How to use the adobe sign and seal?
Hello Warcup
Considering PDF files first thing and most important is to make sure that the PDF file is enabled before applying the signature, so to make sure that its enabled you need to check the top bar of the Adobe Acrobat Reader that there is no warnings also for the signature field when you click on it nothing happens that means that the file is not enabled, to enable the file you need to go to file -> save as -> Reader extended PDF -> Enable additional features -> click save now button, then the document is enabled. Then click on tools item and find the button which says “ Apply ink signature “ then you’ll be enabled to make your digital signature hand written using your input device (Mouse).
Also adobe provides their customers with tutorials about their software please refer to this tutorial for further information.
