How to use all possible dell desktop gadgets?
How to use all possible dell desktop gadgets? I would like to display all the desktop gadgets on my computer screen like calendar, organizer, important icons and other gadgets that will probably remind and help me with my daily activities. Give me some explanation on every desktop gadget you know.
Anthony Wendy
Answered By 0 points N/A #180267
Hello Anthony,
You can use a Desktop Calendar and Personal Planner. This will help you manage your in an orderly manner so you will not overlap on your tasks. You can set up your appointments and alarms for meetings, birthdays, anniversaries, events or tasks just by simply entering the dates. It is a window gadget that you can move around your desktop which makes it easy to access. You can also personalize its look from time to time.
There are lots of downloadable software. Systems supported are Windows 95, Windows 98, Millennium, XP, Windows Vista, and Windows 7. Sizes usually range from 2.54 MB to 14 MB.
You can check this free 30 day trial software out for starters.
