How to use android gps maps philippines?
Hello experts,
How to use android GPS maps Philippines? I have a mobile phone with android operating system and don’t know how to use the GPS map in the Philippines to appear in my Facebook, twitter or other social networking related sites. I hope you can give me some advice.
Thank you.
Best Answer by Gertrude Nelson
Answered By 0 points N/A #187717
There are very few devices are available in the Philippines. Garmin device is the only useful device in Philippines because this device offers GPS in Philippines though it is not completely perfect. The Garmin provides some GPS application for their android users. So that you can use Garmin devices if you want to get GPS opportunity in the Philippines.
Answered By 5 points N/A #187718
Dear,
GPS maps are compatible with Garmin devices. Garmin provides some applications for Android users. To install GPS maps, you will first install Navitel on your Android operating system. Then run Navitel and exit. You can copy all maps to your SD card. If the maps are not properly indexed, click setting – next – reset all. This will reconfigure your Navitel and index all maps.
Thank you.
