Devinuhler
Posted on - 02/03/2013
Hi TechyMore
Teach my question is about android. It is possible to use the runtastic offline mode in android?
There are any requirements to use that such an application?
What are the steps to activate the android runtastic offline mode?
How to use Android runtastic offline mode
Hello Devinuhler,
Yes, it is possible to use the runtastic app in the offline mode. There's nothing you have to do except disconnecting your Smartphone from the internet.
In offline mode you won't be able to access the remote data like maps and the online elevation isn't available. Also, the measurements won't be accurate as they would be if you are online.
Once you're connected to the internet again your maps will be loaded and session uploaded.
If you want to try the app from Runtastic, you can download and update to the latest adidas Running App. It was recently updated on April 24, 2020 and is rated 3+. The app is ad supported and offers in-app purchases. The app allows you to map your activity’s mileage, time, speed, distance, elevation, calories burned, and other stats.
Among the features include:
- Easy run tracking in real time with built-in GPS
- Track your running statistics to evaluate your training and exercise patterns
- Customize the app’s dashboard
- Receive training guidance and audio feedback from the customizable “Voice Coach”
- Live tracking and cheering to let your friends know that you are out and about
Now, if you want to try the app in offline mode, just disable or deactivate your Wi-Fi or data connection.
