How to use array in Switch Case PHP
Hello! I’ve been trying to use array in switch case but I’m confused, can anyone teach me how to combine this two, is this possible? Thanks
Hi Stanley,
First, you need to decide what do you want to do inside the looping of each array element and the case labels. Here is the basic construct.
<?php
$in = array(1,2,3,4,5); // fill the array with your case labels
foreach ($in as $a) // loop for each element in
switch ($a)
case 1:
echo '1 is in the list';
break;
case 2:
echo '2 is in the list';
break;
case 3:
echo '3 is not the list';
break;
case 4:
echo '4 is not the list';
break;
case 5:
echo '5 is not the list';
break;
default:
echo 'No Match Found<br />';
I hope it helped.
Notifications
