How to use as3 code to open outlook?
I can’t open MS outlook using the Action Script 3 because it’s blocking the command. I tried several codes but it’s still no use. Also followed the instructions on different websites but still the results were the same. Is it possible that the MS outlook was the problem or its compatibility?
Best Answer by Navarro Kerber
Answered By 0 points N/A #190286
Hello
I would like to suggest you some effective code to implement a button to open outlook.
However if you wish for a plant page to open (and configure it) you might remove the '_parent' parameter.
Hope it helps.
Answered By 0 points N/A #190287
If your intention is to start Outlook automatically at each computer reboot, then one simple solution is to drag and drop the shortcut to Outlook to the "Startup" folder found in the Start menu.
Note that depending on which other programs and services are set to run automatically at startup, placing too many shortcuts in the "Startup" folder may lead to longer times where the computer is unresponsive.
