Good day all,
A short and hopefully simple question to ask from a newbie. I have downloaded a barcode 128 font for a word processor application, but I do not know how to use it. Whenever I try to use the font, it just appears as text but not the barcode. Anyone knows why it doesn't appear as barcode when it should be? Is there something wrong with the font file?
How to use Barcode 128 font for Word processor?
Good day Elija Hale Jandroo!
The barcode 128 font does not appear as barcode when you use it. To correct this, you should select the text that you typed and change the font into the bar code typefaces. This should enable you to view you text as a bar code.Â
Hello Jandroo,
Bar Code 128 3.8
These bar codes are made for typefaces or font. Just select the text and change the font to bar code typefaces. If you used bar 128 for utility, you should build a bar code string and then copy the string into the clipboard. Make sure you only copy the string. In this package, you need to change font for that string to any 12 bar code you want.Â
Here you will find the User Guide and FAQ. Like:
Bar codes won't scanÂ
Clip board copy doesn't workÂ
Making a taller bar codeÂ
Mail Merge ProblemsÂ
Text appears instead of bar codesÂ
Hope this will help you.
Thank you and have a good day.
