Hi
When using my Sony camcorder program, it shows a message saying that, `this application you need Macromedia Flash Player’.
I installed `Adobe Flash Player’ first and tried again, but the same message comes up.
What would be the problem in this case?
How to use camcorder program
If you have installed Adobe flash player and the application is still unable to play the video, it simply means that the flash player you installed is not compatible with the ones you have. You may need to install another flash player, preferably macromedia flash player.
Incompatibility with the version you have installed will also be another thing you may want to look at. Usually when we buy camcorders and camera, they come with CDs or DVDs with the player that can be installed on our computer. You may want to check the internet with free macromedia flash players available for download.
One example of site is this http://www.brothersoft.com/
