How to use Chrome Speech to text MP3
Chrome speech to text MP3 can convert any voice into an accurate text in the Chrome browser. Can anyone give me directions on how to use it?
Actually that's only available with google translate and only limited to english language , hopefully that will change in the future as it's still a brand new technology and very limited
If you want to use it with google translate in translating from english , first make sure you have Google Chrome 11
Then select the english language , click the microphone in the input box and say the words or phrases you want to translate
To start, know that you happen to be employed Yahoo Firefox 11 as well as after, along with that you've got a microphone. Upcoming, you must find the way into a web site in which helps the new talk API. At present, that's limited by Yahoo change, that it is limited for you to translations in which come in English.
Anticipate in which to switch as web site designers begin to implement the particular element. An added hitch can be in which since this is a brand-new element, it's also minimal at present inside Yahoo Change for you with translations originating in English.
Therefore: Collection Yahoo Change for you in English, then click the microphone in which shows up from the cheaper right-hand part in the feedback package. Communicate the particular phrase you desire to convert.
When you are speaking, Yahoo will certainly immediately change this. Also you can utilize the web-site's Hear solution (to the proper in the wording field) to listen to what exactly is the particular translation seems like.
I hope I have given you right answer.
Well explain guys and thanks to both of you. Whudson Audrey, your answer is reliable and easily usable to me. Reading your answer, I see that to use this I need to do some work. First of all, I will make sure that I’m using Yahoo Firefox 11. Next I need to select English language, and then click microphone and other works. Your description is excellent and following your instruction now I am able to use it. Whudson Audrey, you have done a great job.
