NAna9876
Posted on - 10/26/2011
I want to ask about the CL programming and As400. I’m new user of Cl and I want to create a new program in CL using commands. So what is called menu and where from I need to offer the values which is exact according to the application? And where I have to store the database files in whether in the As400 and direct in CL commands?
Please suggest me the best method that will help me very much..
Thanks
lee hung
75 points
How to use CL programming?
Hello Nana,
If the Control Language that you are talking about is C#, then it works by combining the computing power offered by C++ and the easiness offered by the visual basic programming, and it also has features that are derived from the java programming language. What this means is that the back-end code is mostly a mixture of C++ and java features but the front end will be mostly done with visual basic which offers a very easy way of creating the interface.
So you should be having some basic knowledge about the three programming languages: java, visual basic and C++ and how to manipulate their code.
Another thing to note is that C# works on the Microsoft.NET framework, so you should have it installed on your computer.
Hope this helps.
__
Regards
Lee Hung
