How to use Cloud on Toshiba AT100
How to use Cloud on my Toshiba AT100Tablet, as elderly and having trouble with its use. Where can I find it, and how do I get it on my tablet?
Hi
One problem in Pakistan is our government institutions are not performed well. Because in Government institution teacher doesn’t work so much they first of all don’t attend the classes and if they attend the class they ask students to study and they just sit on the chair and do nothing. This should be demolished from our society. Now it has been improving to some extent but yet not solved completely. Thanks you like this answer and you will get this situation into trouble in very short time and in less than time you can find the situation Thanks, Hope you like it.
Here are the specs for the Toshiba Thrive AT100. The Toshiba Thrive AT100 tablet is a 3G device operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on June 2010 and released on July 2011. Unfortunately, this tablet has been discontinued and is no longer in production. It measures 273 x 177 x 16 millimeters and weighs 725 grams.
It uses a mini-SIM card. It has an IPS LCD capacitive touchscreen display with 16M colors at 1280 x 800 pixels screen resolution. It supports multi-touch. It runs on Android 3.0 Honeycomb upgradable to Android 3.2 Honeycomb powered by NVIDIA Tegra 2 T20 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and ULP GeForce GPU. It supports an SD card expandable up to 32 GB.
It runs on 1 GB RAM with internal storage available in the following capacities: 8 GB, 16 GB, and 32 GB. The primary camera supports 5 megapixels with autofocus and can record video. The secondary camera supports 2 megapixels. It supports a 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot, Bluetooth, GPS with A-GPS, miniUSB 2.0, and USB 2.0. It has built-in accelerometer, gyro, and compass sensors.
The pre-installed web browser supports HTML5 with Adobe Flash. Java is supported. It runs on non-removable Li-Ion battery with talk time up to 7 hours. It is available in black color. Since the Toshiba Thrive AT100 tablet supports 3G network, it is very easy to connect to the internet. The device can connect to any 3G-capable cellular network and Wi-Fi network.
To be able to connect your tablet to the internet using 3G, you must first contact your network provider and subscribe for an internet data plan. Once you are subscribed, that’s the only time you will be able to connect your tablet to the internet.
Also, if your area is covered by a free Wi-Fi network or an unprotected Wi-Fi network, you can connect your tablet to that Wi-Fi network and be able to connect to the internet. To do this, go to Settings and then enable Wi-Fi. Once it is activated, the tablet will scan for nearby Wi-Fi network.
Once the scan is finished, it will display all the Wi-Fi networks available in your area. Select one that is free for public use or a public Wi-Fi. You will know it is a public Wi-Fi if you don’t see “protected” or “protect” along the Wi-Fi network’s name.
If you see any of these labels in the Wi-Fi name, you will not be able to connect because it will ask you for a password unless you know the password then you can continue.
