How to use CMOS setup on my pc?
I know how to use BMOS setup, but I don't know how to enter the CMOS setup.
And how does it differ from BMOS setup.
Do you guys have any idea about this?
Dear Dixon Chapman,
Setting up the CMOS is a very nerve-racking task. You need to be very patient in order to perform it. The common items that you can see from the CMOS setup are the following:
To utilize the CMOS setup, follow the steps below:
1. Press the F2 key or the delete button when your computer boots up.
2. Choose the Load Setup Default option.
3. Input the current date and time.
4. Change the boot order. This mean which drive you want to boot first when you start your computer. Select to boot the hard drive first.
5. Check the CPU settings. The default will be launched. If not, set up the CPU to manufacture specifications.
6. Check the RAM settings. If there is an issue, go to manufacture's website.
7. Enable plug and play features.
8. Turn the Controller on if you will use any USB devices. Enable the 2.0 support to ensure that it will work on their best.
9. If you will use RAID, ensure that you also enable it.
10. If there is an option on your motherboard to keep the fan quiet, enable it.
11. Save your new settings.
Best Regards,
Bacon Medina
Hi Dixon Chapman,
You may use the CMOS for the following purposes
Change booting sequence
Over clock the system
Change system date and time
The following are different set up for different computers
Computer type Key to press
Some Toshiba ESC
Some Toshiba F1
Some NEC F2
Some COMPAC F10
Some IBM and ps/2 model Ins
Some Del Reset twice
Difference between CMOS and BIO Set up
I want to clarify to you that it is called BIO set up not BMOS
BIO in the computer motherboard contain instructions on how the computer will start (boots)
It is updated by the BIO update.
COSMOS on the other hand are powered by COSMOS battery.
It contain system setting and is updated by COSMOS setup
Notifications
