How to use Cpanel OOP PHP to enable automatic software updates?
Use Control Panel to enable automatic software update or what we called the Windows Update to install the important and the optional updates. Open Control Panel, System and Security, on the Windows Update option click Turn automatic updating on or off. On the Important Updates field choose Install updates automatically (recommended) and check the box you want to execute.
Best regards,
Heather marie
It’s quite confusing as to what you are really trying to do. But if you want to enable automatic updates on your Windows, you can do that by enabling Windows Automatic Updates in the Control Panel. To do that, click Start then Control Panel. In the available categories, select Security Center. In Windows Security Center window under Automatic Updates, click “Turn on Automatic Updates”.
This will now alert you if an update is available for your operating system. And also if you wish to show available updates for the applications presently installed on your computer, you may try doing it inside Add or Remove Programs applet in the Control Panel. Click Start then Control Panel. Select Add or Remove Programs. In the Add or Remove Programs window on the upper part opposite to “Currently installed programs and updates”, check “Show updates”. This might display any available updates for the specific program if your computer is always connected to the internet.
