How to use cyanogenmod 7 jelly bean style for android ?
How can I use CyanogenMod 7 jelly bean style for android ?Need to know how to customize it for other versions as well.
Thanks
Thanks
Android is a Linux based open source operating system for Smartphones and tablet computers. You want to setup CyanogenMod 7 jelly bean style for Android. Dear Ashley you should mention about your device. Sometime it can be vary with your device. Ok now I am going to write some common steps to do this:
1. Setup your device manager for your PC.
2. Create a backup of your device.
3. Ensure that your device battery is charged at least 60% – 70%.
4. Now flash your device with Android 4.0 Ice Cream Sandwich Rom.
5. Root and install ClockworkMod recovery on your device.
6. Download CyanogenMod 7 (CM 7) Android 4.0 Jelly Bean Rom.
7. Download Google Apps package and also download CM7 Dixex.zip file.
8. Connect your device with a computer using a data-cable and load all the downloaded zip files.
9. Disconnect your device from the computer and turn is off.
10. Now active the recovery mode of your device and setup all the downloaded files.
Follow these simple and common steps to setup CM7 to your Android. But you should mention about your device, because setup process can vary with your device.Â
