How to use double twist for ubuntu?
I'm in problem with using double twist for ubuntu. How can I use it? Is there any way? If yes, please tell me in details.
Thanks
Thanks
Double twist is available for Ubuntu however, lots of users are having problem with it. You can install it but you can’t launch the program. Only windows and mac users can use the double twist since these are the only operating systems where the application is compatible with. I suggest that you uninstall it and wait for a double twist version which is compatible with Ubuntu.
Hi Rabecca,
You can use Double twist Ubuntu to sync your music to your phone that is using Android OS. To make sure you do this successfully you can use Amarok 1.4 to make your phone as the generic audio player. Aside from this you can sync over wifi, it can make syncing with desktop or other media easier.
Notifications
