How do you use easy Icon Maker 5? Can I extract images from any format? I have just downloaded the program and I'm still learning how to use it. How is easy Icon Maker 5 different from the older versions?
Easy Icon Maker 5 is software for icon making, editing, changing, extracting, searching and exploring.You can extract images EXE or DLL file.You can also import graphics file like BMP, JPG or GIF and save it into icon file or export icon file to graphics file.To know more visit this site: http://www.icon-maker.com/
For using this Easy Icon Maker software you can see the wonderful video from YouTube.
You can use an easy Icon Maker 5 to create and edit programs that have an interface that consists of color palette and drawing tools. It is a very user friendly and small icon that can be used in extracting, icon making, changing searching and also exploring. The easy icon maker 5 is different from its previous versions as it has enhanced tools that include: Icon Searcher, Icon Changer and Icon Extractor. http://www.icon-maker.com/
1....
