How To Use Epson Scanner Using Some Simple Steps
Hi. To learn how to use Epson scanner, first, click on the first page of the document and then begin the scan of Epson. Then, in the Epson scanner, set the mode of scan to the home node, select the basic settings and the destination for the way in which you will use the images. Then, preview the image following which select the area which is to be scanned. After all the previewing is done, click on scan.
Then, select PDF as the type after which the settings of the current PDF will be displayed below it. Then, select the file options and after you are done, click on OK. Your page will get displayed in the window. Next, save the file after which you will be shown a thumbnail image of each scanned page. Next, click on OK and your file will get saved in the folder after which the Epson scan should be closed.
Hope we helped.
