How to use a flash Drive as a RAM on XP
Hey there,
I recently heard that windows has an option to increase the physical memory of the system using a flash drive. However I do not seem to find the option to do so. My computer has an internal physical memory of 256 MB which makes it sluggish. Do you have an option to increase its performance without actually upgrading it?
Many thanks,
Samantha
