How to use free .wav to word convertor over Wi-Fi connection
Can I use free wav to word convertor to integrate directly with the word files on my laptop? Also can we use it over wi-fi between two laptops to convert files.
Hi
Yes you can use the software directly on your computer to convert wav files to word files. And also you can use it on wifi network also. But you have to set permission first. To do that follows the steps.
Then you can use the software through wifi network.
Hi Kim brauer,
Regarding your question, you must understand that while there are software that allows automated transcription from .WAV files to text, there are the following things to consider:
1. You are unlikely to find them built into Word or any Office programs you might be using.
2. Available transcription software usually only record from a device like a microphone straight to text.
3. Even the most accurate speech recognition software will probably not work for audio recordings with multiple people talking, such as meetings.
Hope this helps.
Murakami Wyatt
