Hello fellows,
How to use Google chrome desktop cleaner? I haven’t seen this feature in Google chrome but some are telling me that it is a plug in for Google Chrome internet browser. I need to make things clear regarding this matter. I have to use important updates and features to protect my computer windows 7 operating system registry.
Kristin Runaldou.
Google chrome desktop cleaner is a powerful and useful tools that allows user to maintain the cleanliness of your Pc. It is designed to clean your desktop from unused files and shortcuts. You can include files and folders that are included in the cleaning process. Here you can modify your setting that you want to happen during the operation of the software. Open your application and it will display your entire files that are currently on your desktop in your ‘Clean your Desktop’ tab. Here you can perform the setting you have modified. Here you can choose the file you want to clean, and you can place it also in a folder where you can restore those file when the files are needed.
Regards
