Mili Nelson
Posted on - 04/02/2013
Hi all techyv users,
I am finding some of the problem how to use html color for Microsoft windows vista home basic pop up, I have recently installed it.
Earlier, I was using Windows 7 operating system, but now Microsoft windows vista home basic fixes some problem on my desktop.
An anyone please advise me how to use html color for Microsoft windows vista home basic pop up.
How to use html color for Windows pop up
Hello Nelson,
In combining red, green, and blue light, colors are displayed. The combination of red, green, and blue color values using hexadecimal notation or HEX are called HTML colors.
I will give you a link and this link will gives you an idea on how to use HTML colors.
Click the link below.
https://www.w3schools.com/html/html_colors.asp
Hello Mili Nelson,
If you want to use Html colors then you have to use the HEX values of them so that you can use them in your desired place. But you can also choose that according to your desire.
But you can also change it according to your desire by using the manual option of the colors. From the below link you can get how to use that thing and also you can get different values of HEX code for changing the color and also you can get that how to use that thing in your windows.
http://fabrikar.com/forums/index.php?threads/how-to-use-html-code-in-window-in-edit-list.27857/
