Please tell me how to use an Idx to ssa converter. I want to convert my idx based short movies to ssa subtitles. My friend who also makes short animation movies said this is more convenient for the subtitles, that I can use notepad for editing. Also, is it true that I can include information about me (the film maker/author/etc) of the short movies on it?
I still do not know what software I can use to do this. Please give me some suggestions and a few steps on how to use a tool that can do this.
How to use Idx to ssa converter for movie subtitles
–You can use subtitle converter for convert IDX subtitle in to SSA.
–SSA subtitle can easily editing using the notepad and yes it is true that you can insert the information about the film maker, author etc., using SSA subtitle.
–Mostly there are lots of subtitle converters available and most famous ones are Subrip and Vobsub.
–You can download Vobsub using the below link
http://www.afterdawn.com/software/audio_video/subtitle_tools/vobsub.cfm
After that you have to install Vobsub into your computer and run it.
To start the converting process select SubResync menu from the application menu.
Then open your subtitle file which you want to convert into SSA file.
You can edit the subtitle file after open it and timeline panel shows the information about existing subtitles.
Finally after the editing work done, you have to select the destination folder for save your subtitle files into SSA format.
Remember to select save as type in to SSA
Thank You,
John major.
