Hello friends,
How to use industrial windows XP wallpaper? I downloaded some wallpaper related to industrial in my windows xp operating system. I just don’t know how to apply the changes. Can you give me some ways to pick one out of ten industrial pictures and set it as wallpaper?
Thanks and Regards,
Greqory Gregory.
How to use industrial Windows XP wallpaper?
Hi, industrial windows XP wallpaper, just like any other image files, can easily be transformed into your XP's wallpaper. Just right click on the image of your preference, then click on "set as desktop background". Alternatively, you can also go to your screen's property, then go to Desktop, then browse through your industrial wallpaper. Picking the best picture is really matter of personal preference.
lee hung
75 points
Gregory,
One way to change your background or wallpaper once you have saved your images is done through the control panel. First, click on start and then choose control panel. Once the control panel is open, choose "Appearance and Personalization". You will now need to click on "Personalization" and choose "Desktop Background". After, the "Desktop Background" window comes up you will want to "browse" to the folder where your pictures are. Once you are in the folder double-click on the image you would like to use. The last thing you will want to do is click on "How should the picture be positioned", here you can fit it to the entire screen or pick to have it outlined by a color, after you have made your choice choose "Ok".
