tia heyen
10 points
Posted on - 05/23/2013
Good am! I just bought my first apple product yesterday and there are some things that I have not yet discovered with my iphone 5. I really don't know how to use this iphone contact file viewer. Can you please explain to me the use of this app? Is it important or should I just delete it? Please reply.
How to use iPhone contact file viewer?
Hi Tia Heyen,
For me iPhone 5 is one of best mobile phones ever. I think this application should help you to transfer contacts from your iPhone to your computer with USB. So I think you should leave this application and do not try to delete this. It is a very small application and it will not significantly affect your disk space on your iPhone.
