How to use an ISO file for playing games?
I want to know if it is possible but i wish to play iso files, i kind a need this right now, but am not sure if it is possible, please if someone knows, tell me here
Hello Wallace,
The line "Possible wish to play ISO files." that's kind of unclear. But Anyways. I would like to define ISO the basic and simple way and how to use it.
I assume you know that ISO is an Image file format, created by Soft wares like Power ISO, Ultra ISO, Daemon Tools, Alcohol, and etc. Image files are like virtual Disc mounted to Virtual Drives in order to read its content or Play it(Basic Purpose), They're widely use for Game Installers, Video, Music and for storage purposes.
ISO files can only be played when you have VIRTUAL DRIVER and the software that has created it. Without the above mentioned software. The ISO file can not be opened by any other file viewer.
Hope this helps.
