annie brown
20 points
Posted on - 04/05/2013
Could you advise me how to use java mdi form web browser based? I am asking about Jdic using. For opening the single browsing it works well. But my needs are to open this browser in mdi form. When I tried to open that, there was a problem. First page can be opened and everything is ok with that, however, supposing to minimize and restoring this page makes it got cleared and after that this page can’t be refreshed. The trial to open more browsers gives this again and again, so, nothing works as the result. How to solve this?
How to use java mdi form web browser based?
When your using the MDI application in opening multiple windows such as word, access or excel. In a manner, all windows under MDI application is totally under the Windows of MDI, in short if you open a single window, the previous window you have opened will automatically become and icon at the bottom of the desktop. It is the same manner when you minimize a window under the MDI application.
You can use swing version which allows you to create MDI applications and could able to open multiple windows. Each new window under swing version is totally independent from the mother window. Swing allows you to detect and solve every problem at MDI.Â
Hello Annie Brown.
            If you want to do the above task then all you need is to read the source code that is provided to you. It is a bit difficult but if you have some knowledge then you can easily get it and you can use it in your source code. All you need is to download the code and after that you need to pick your desired part of that code. There is an attachment with this comment which contain the source code.
