How to use Kaspersky Gadget in Kaspersky Internet Security 2012?
I want to use Kaspersky Gadget in Kaspersky Internet Security 2012. How can I do it? Please, tell me in detail.
Thanks
Don
Thanks
Don
Hi
You want to know that how can you use Kaspersky gadget in Kaspersky internet security 2012.
 It's  very easy to use at first you have to start the gadget on your PC then configure on your PC.
You can a Kaspersky logo on your PC desktop you should have to go  the bottom like hand tool click on the button
Then you can see 4 options that numbering 1,2,3,4, you should to setting all those options manually .
Click on the number 1 it should be "run up debt" to do it "reports" , 2 is tax manager you do it "setting", 3 is "reports" you do it "safe run for application" a date last number 4 it "safe run for application" you done it "network monitor" then click the ok button. So if you need to edit it click on the Kaspersky shortcut logo right button on your mouse and go to setting that window has some part that is protection center, scan, update and advanced settings. That's part have some sub part you can control it by your own need but always remember one think this software only for 32 bit windows .
I think this solution can help you and your personal computer  thank you .
