How to Use Laptop without using its Broken LCD Screen?
Hi, this is Mohsin, I just want to ask a question about broken LCD of my Laptop. Is there any way that I use my laptop without using its LCD Screen, as it is broken down and I don’t have enough money to buy a new LCD.
Cheers…..Mohsin.
Best Answer by Ace Baker
Answered By 5 points N/A #84517
Hi Moshin,
Yes there is still a way for you to use your laptop even while your laptop screen is broken. The only way of using your laptop with a broken LCD screen would be to attach an external LCD screen that will act as a substitute for your broken screen. You could either use a spare monitor screen that you have or a Television that has a HDMI port to attach your laptop to the Television. Another that you can do is to use a projector as your external screen. I hope this solves your problem with your laptop screen.
Regards
Answered By 0 points N/A #84518
There are different kinds of video output hardware that can fix you problem. Attach a monitor to your laptop by either way: USB or VGA or HDMI. Simply press the FN button on your keyboard and the Output Key so that it will do a dual display or send the display to the attached monitor.
Also you can buy a projector if its financially possible for you. Just like the monitor, it will just do the same but has a different kind of way to output you operating system.
Hope this helps you on your problem on not using your broken LCD anymore.
