Hello experts,
How to use launcher in bolt app? I got some problem on using the launcher in bolt app for there are some instances that it doesn’t run or I don’t know how to make it work. Guys, I need your help on the step by step process on using the launcher in bolt application. Thank you.
Hello Deborah,
There seems to be association problem with the application launcher of your application. Simply uninstall the old program, Download the latest version of bolt application on your mobile and install it. The download link for the application is: https://bolt.en.softonic.com/java After installation Restart your phone and launch the application.
This should work fine.
Hey,
It is very easy. After you buy launcher, you need to but the ammo which costs you 500 coins for 330 ammo. For example let's suppose you want to destroy the giant pirate ship that flies overhead. You have to wait until and unless the big pirate flies past you at the background. Then the ship will try to shoot you; at this time position of the ship will be foreground and at the edge of the screen.
You just need to start tapping rapidly to shoot it rapidly. And please note don't tap too far at the right of the screen, it might pause the game. Just aim properly and tap. Same is the process for shooting any other enemy objects. It's little difficult. Tapping practice will make you perfect shooter.
